Filter not working.
Status: Closed · Asked by Admin BHM on · 0 views
BHM — Question ·
Task History ID: Task History ID - IjU3NjUwNTZjMDYzMjA0MzM1MjY1NTUzMDUxMzc1MTYzNTQzNDBmMzMi_pc
So I have a filter that's got many different words to stop my automation from continuing. The filter has several 'or' conditions within the filter step. There's probably 30 of these. They're all set to 'doesn't contain'.
However, as per the attached screenshot - the action after this step still fired.
What's the issue? Is this a bug?
Hi @BHM,
It seems that you made some changes to your workflow after this task was executed, which is why we are unable to determine the cause of the issue you encountered. Please monitor your workflow for a while, and if the issue occurs again, kindly let us know without making any changes to the workflow.
https://drive.google.com/file/d/1hEP_95Vgfz6QAGQ6AC6e0PmXcr3Nhvxq/view?usp=sharing
