digitaldivi
Dear All,
I have a form in my website.
On filling the form:
Initially, i tried directly to add a contact from Fluent Forms Pro to Sendinblue. I added API v3 etc but contacts are not getting added on succesful submission form.
I gave up on that.
Later, I sent the data from FF Pro to Google Sheet (via integration) then using Pab Connect from google sheet, iam trying to add the contact to Sendinblue.
I set up the flow and on Testing Save & Send Request, a contact got added successfully.
Now when the form is filled, contacts are not getting added to Sendinblue.
but data is getting filled in GS from FF Pro.
It seems, Webhook not triggering at all.
Iam confused now. I placed the Pabbly Connect extension to Send on Event on Google Sheet.
Am I missing something, while using Fluent Form Pro to GS.
Pls help.
Thank you
Regards
Krishna M
I gave up on that.
Pls help.
Thank you
Regards
Krishna M
