Google sheet + Zoho books problems
bilol
I've watched the video about creating zoho customers using google sheets. It is working if I copy and paste in Google sheet, but my google sheet is filled automatically when users fill the form in my website. And Pabbly is not sending enough information to Zoho books, it is sending only addresses, names and etc. , but the amount, currency is not sent.
Can someone from support help with these issues?
Fagun Shah
For the first part of the issue, If you are using google sheet as a trigger and data is coming to google sheet from third party API then you need to check mark both Send On Event and Send On Schedule in Pabbly Addon.
Also if data added manually or via google form has instant trigger and data added via API will be sent to pabbly connect every 1-hour. - https://www.pabbly.com/common-problems-with-google-sheets-integration-in-pabbly-connect/
For 2nd part of issue someone from @Pabbly or @Supreme Verma will help you.
Supreme
Can you please share your workflow link so that we can review it and assist you better?
