Google sheets integration with Zoho Crm problems
CarlS
I set up my integration with google sheets via Pabbly to Zoho CRM but the 250 leads I have do not all download. only about 150 did. Not sure why. This was a google sheet that already had the leads so I checked download all.
Hey @CarlS
You can only use "Send On Event" when setting up Google Sheets if the data is coming from a Google application or if you manually enter it. If the data is coming from a third-party application, however, you may need to choose "Auto Send On Schedule" and "Send on Event," which will forward the data in exactly one hour.
Additionally, make sure the data is filled up to your trigger column.
