Help needed capturing Slack thread replies in Pabbly Connect
Status: Closed · Asked by While Digital on · 0 views
While Digital — Question ·
Consent to Access & Modify: I don't authorize Pabbly Support to log in to my account.
Hi Pabbly Connect Team,
I am currently using Pabbly Connect with Slack and I would like to capture replies that happen inside a specific message thread.
Right now, I can trigger workflows for new messages in a channel, but I am not able to capture responses or replies within a thread (thread replies). My goal is to automatically trigger an action whenever someone replies inside that thread.
Could you please guide me on:
  1. Whether capturing Slack thread replies is supported
  2. Which trigger or event I should use
  3. Any setup steps or configuration required to make this work
If needed, I can share my workflow details or screenshots.
Thanks in advance for your help.
Best regards,
Suraj
Hi @While Digital,
Thank you for reaching out and for clearly explaining your requirement.
To check this in detail and guide you accurately, we request you to please share the workflow URL that you have created in Pabbly Connect. This will help us review the trigger and configuration you are currently using and verify how thread replies are being handled in your setup.
Once we have the workflow link, we will review it and assist you accordingly with the correct approach or any required adjustments.
While Digital — Reply ·
Workflow URL : https://connect.pabbly.com/workflow/mapping/IjU3NjcwNTZjMDYzMDA0Mzc1MjZlNTUzMjUxMzEi_pc
Thats what im trying to achieve :
Trigger:
  • App: Slack
  • Event: New Message in Thread
  • Channel: #implant-followups
Action 1: Lookup Original Instruction
  • App: Google Sheets
  • Action: Lookup Row
  • Search Column: Thread ID
  • Search Value: {{trigger.thread_ts}}
Action 2: Update Google Sheet Row
  • Action: Update Row
  • Row Number: {{lookup.row_number}}
  • Update Fields:
    • Erin's Response: {{trigger.text}}
    • Response Timestamp: {{trigger.timestamp}}
    • Response Time (mins): Calculate difference
Hi @While Digital,
We have checked your workflow, and the trigger behavior is expected.
At the moment, Pabbly Connect does not have a separate trigger to capture only Slack thread replies. The Slack → New Message trigger captures both:
  • New messages are posted directly in the channel
  • Replies posted inside a thread
From your trigger responses:
  • Response A → regular channel message (no thread_ts)
  • Response B → thread reply (contains thread_ts)
Recommended approach (this should work for your use case)
Add a Filter immediately after the trigger:
  • Condition: thread_ts exists
This will ensure the workflow continues only for thread replies.
After the filter, you can safely:
  • Use thread_ts in the Google Sheets Lookup Row
  • Update the relevant row with the reply text, timestamp, and calculated response time
No additional Slack trigger or configuration is required—your current setup is correct, only the filter is missing.
If you face any issue while adding the filter, feel free to let us know.
How can i get/fetch the text, which is added in the thread reply
Hi @While Digital,
Thank you for reaching out.
Currently, there is no native action in Pabbly Connect that exclusively fetches Slack thread replies. However, this can be achieved using the Slack: Custom API Request action as a workaround.
Please open the required Slack channel and run the following command:
/invite @pabblyconnect
Please let us know once this is done, so we can add and test the action from our end.
hey its not working can you give me some email id, where i can send the invite
Hi @While Digital,
To assist you with this more effectively, we would need to connect over a Google Meet so that we can review the setup and guide you accordingly.
Please schedule a convenient time using the following booking URL: https://calendly.com/d/cxp2-cym-f3b/support-from-pabbly-preeti
Once the meeting is scheduled, we will review the configuration and assist you further.
Hi @While Digital,
Thanks for joining the meeting. I hope your queries were resolved and the workflow is set up properly.
Since you’ve been a long-time Pabbly customer, it would be really helpful if you could share your feedback. Your review can help other businesses understand how they can benefit from using Pabbly Connect.
You can share:
Thanks for your support.
