Help with filter option
Status: Closed · Asked by Ahmed Adel on · 0 views
Ahmed Adel — Question ·
hi team i use filtter option to select task that completed in notion when i tested it like first screanshot the status was success but when it run automatically i get error how can i solve this issue Although in the past it worked for a year without any problems
Hi @Ahmed Adel,
Could you please share the Task History ID in which you encountered this issue?
