Hi , i need some help in integration
Affan Ali
I have a custom form plugin and i want to integrate Pabbly connect in my custom wordpress plugin for my users , i searched a lot but did not get any useful link or code ,
kindly help or share the links which could help me .
thanks in advance.
Supreme
Hey @Affan Ali
If you have the Rest API of that application then you can use it in the API by Pabbly action step to use the application in your workflow.
To use the API by Pabbly action step you can refer to the following video tutorial.
