How do I get Pabbly to work with Gmail?
Status: Closed · Asked by Deepicka Mehta on · 0 views
Hi Deepicka,
We reviewed your workflow. You have connected Gmail (New Email) to Slack (Send Channel Message), but your current workflow does not include a Filter by Pabbly step.
If you want to send Slack notifications only for emails matching specific conditions, please follow these steps:
Click the (+) icon between Gmail and Slack and add Filter by Pabbly.
Select the Gmail field you want to check, such as Subject or Body.
Choose a condition, such as Contains, and enter your required keyword.
Save the filter. Keep Slack after the filter so that only emails matching your condition proceed to the Slack action.
In the Slack message, map the relevant Gmail fields to include the email details.
Example: If you want Slack notifications only for emails whose subject contains “Invoice,” set the filter to Subject → Contains → Invoice. Emails matching this condition will proceed to Slack; emails that do not match will stop at the filter.
Please note that the Subject and Body fields must be available in the Gmail trigger response before you can use them in the filter. If they are missing, test the Gmail trigger again with a new email.
You can refer to these tutorials:
Gmail trigger setup: https://www.youtube.com/watch?v=d8Z8j3H_vvw
How to use Filter by Pabbly: https://www.youtube.com/watch?v=W3HMbI5Q68U
Gmail to Slack integration: https://www.pabbly.com/how-to-connect-gmail-to-slack-using-pabbly-connect-a-step-by-step-guide/
Hello!
Just a quick follow-up to check if you need any further assistance from our side.
Soumya Tripathi
Customer Support Lead
🌐 Pabbly.com
🎉Black Friday Early Access
I've attached a screenshot, on the filter option there's no where it shows subject, body, etc. Currently just showing abstract details. If you can help to filter the subject and body I can take it from here. Thank you.
Actually I was finally able to get it to work per the videos you shared. Thank you for that. Is there a way I can filter the information received from a gmail email (ie specific client name, email, details) and trigger slack? For example, if from 17Hats my CRM I receive an email for a booking confirmation. They automatically send a temlate email (Booked, and subject has client name and details). 17Hats unfortunately has only minimal zapier integration and no accessiblity with Pabbly as of now.
Is there a way, the email can be filtered, the Client details pulled and sent to slack?
Hi Deepicka,
Thank you for the details! We're glad to hear that you were able to get your previous workflow working.
Yes, you can use Email Parser by Pabbly to capture booking confirmation emails from 17Hats, extract the required client details, and send them to Slack through Pabbly Connect.
Please follow these steps:
Set Up Email Parser by Pabbly: Create an email parsing mailbox and forward the booking confirmation emails from 17Hats to the parser's email address.
Extract Client Details: Configure Email Parser to capture the required information from the booking confirmation emails.
Create a Workflow in Pabbly Connect: Select Email Parser by Pabbly as the trigger app to capture the parsed email data.
Filter Emails: Use Filter by Pabbly to process only specific booking confirmation emails based on the subject line or other available fields.
Extract Specific Information: If you need to extract details such as the client's name, email address, booking date, or other information from the email body, you can use Text Formatter by Pabbly to format and extract the required text. Alternatively, you can use OpenAI to extract specific information from the email content and return it in a structured format.
Send Details to Slack: Add Slack as the action app, select your desired channel, and map the extracted client details into the Slack message.
Test the Workflow: Test the complete workflow to ensure that the correct details are extracted and sent to Slack.
Since 17Hats does not have a direct integration with Pabbly Connect, this approach can help you automate the process using its existing email notifications.
I've previously tried to use email parser, but the issue I came across was gmail requested verification by accepting the link and didn't find a way to verify the email link via email parser as I can't access that account. Is there a way around this? I've set up forwarding via gmail but verification step is the limited factor. Can you help with this? Once set up, is there a way it can grab info like the sent address to the client, subject and body?
Hi Deepicka,
Thank you for clarifying the issue.
Regarding the Gmail verification step, if Google requires you to verify the forwarding address by clicking a confirmation link, you will need access to the Gmail account or mailbox where that verification email is received. Email Parser cannot bypass Google's verification requirement.
Please try the following options:
Verify Gmail Forwarding: Open Gmail settings and navigate to Forwarding and POP/IMAP. If a verification email has been sent, open it in the Gmail account receiving the verification request and click the confirmation link.
If You Cannot Access That Account: You will need to obtain access to the mailbox or use another email address that you can verify. There is no supported way to bypass Google's verification step.
Extract Email Details: Once forwarding is active and the booking confirmation emails reach Email Parser by Pabbly, you can configure it to extract the available information, including the sender's email address, subject, client name, booking details, and relevant content from the email body.
Send Details to Slack: Connect Email Parser to Pabbly Connect, then map the extracted fields into your Slack message. You can also add Filter by Pabbly to process only booking confirmation emails matching your conditions.
Important: The exact fields that can be extracted depend on the structure of the 17Hats email template. You may need to configure the parser using a sample booking confirmation email first.
If you can access the Gmail account but the verification email is not appearing, please let us know so we can guide you through the next troubleshooting steps.
Hi Deepicka,
I am checking in to see if you have had a chance to attempt the verification steps for your Gmail forwarding.
Please let us know if you were able to access the verification email or if you are still encountering any difficulties with the setup. We are happy to help if you have any additional questions or need further clarification.
Hi, so the problem I'm having is email parser set up gives an email to set up forwarding and google is requiring a verification of that email. I can't access that email since it's pabbly's own email. How can I verify that? I think once that step is complete then I can retrieve the other data.
Thank you for explaining the issue.
You do not need to access the Pabbly-generated email address directly to verify it. When you add this address as a forwarding address in Gmail, the verification email is sent to that address. You can follow our video tutorial to see how to configure the Email Parser and Gmail forwarding.
Video Tutorial: https://youtu.be/h-KXriQCu-o?si=lABr8998bzQZKsno
You can also refer to our detailed guide: Pabbly Connect Email Parser Setup.
Once the forwarding setup is verified, send a test email and click Recapture Email Parser Response in Pabbly Connect to capture the email data.
