How to connect birtrix crm to Active Campaign through pabbly?
Status: Closed · Asked by Theertha on · 0 views
How to connect birtrix crm and Active Campaign through Pabbly?
Hello @Theertha,
At the moment, we do not have an integration with Bitrix CRM. However, you can submit a feature request on our public roadmap and our team will review it. If feasible, we will consider adding support for it in the future.
Hai @Preeti Paryani ,
Is it possible to integrate Bitrix with Pabbly using a webhook? If so, how can I set it up?
Hello @Theertha,
Bitrix does appear to support this functionality, and we’ve found a relevant documentation source online that you may refer to. However, for more accurate and detailed guidance on installing Webhooks within Bitrix, we recommend reaching out directly to their support team.
In Pabbly Connect, you can use the Webhooks by Pabbly app to capture data from Bitrix. Once the webhook is set up in Bitrix, the data should flow into your workflow as expected.
