How to Connect Pabbly Connct with Webinar.gg
Status: Open · Asked by doonlawmentor on · 0 views
doonlawmentor — Question ·
How to connect Webinar.gg into connect. It is not natively integrated in Pabbly Connect.
Provide step by step guide.
Its API module and documentation can be accessed here
https://webinar.gg/docs
Hi @doonlawmentor,
You can use the API (Pabbly) module to set up the endpoint you require.
Watch the video below for guidance:
youtube.com/watch?v=xYC5mTobFfc
You can also specify the endpoint you need, and we will attempt to set it up on your behalf.
For example, this is how you can set up the endpoint to create a new webinar.
https://connect.pabbly.com/workflow/share/WhIENlAHB2RUHgRuA2ZXcA8bUlYDWgZiXEUAElJdVCxVGAR_BUQKYFoWV3UAVwFgB04AalENAT1dSVdTA1UEdwceAAIHBFwmURxTKARJCDtaBAQsUDE#
Arshil Ahmad
?Rate your support
doonlawmentor — Reply ·
Hi, Thank you Arshil so much for you reply. Can we add mutiple endpoints in same api module? As I am a nn technical person on api thing. Would it be possible for you guys, to integrate this for me.
The endpoints which we need are as follows
1) Create Webinar
2) Update Webinar
3) Invite user
4) Uninvite user
5) List of invited user
6) Create custom field
7) Create join token (for iframe)
Hi @doonlawmentor,
Thank you for sharing the list of required actions.
We have forwarded your request to our team and initiated a request for a new integration for Webinar.gg. Please note that this may take some time.
We will notify you as soon as the native integration is available.
Hi @Preeti Paryani & @Pabbly , is the integration of webinar.gg done. Kindly confirm.
Hi @doonlawmentor,
Thank you for reaching out.
At the moment, we do not have any updates for the integration of WebinarGG. Please note that our team is currently focused on a few high-priority tasks.
However, we have already reached out to our team to check if there are any updates or plans regarding this integration. Once we receive any information from their end, we will keep you informed.
We appreciate your patience in the meantime.
Hi @doonlawmentor,
Thank you for your patience.
Currently, the native integration for Webinar.gg is still under development and may take some additional time from our team’s end.
In the meantime, we would like to inform you that we have introduced a new feature called Action Builder in Pabbly Connect. Using this feature, you can create custom API-based actions on your own without waiting for a native integration.
If you have access to a Claude API key, you can leverage Action Builder to configure the required endpoints such as:
  • Create Webinar
  • Update Webinar
  • Invite/Uninvite Users
  • Fetch Invited Users
  • Create Custom Fields
  • Generate Join Tokens
We recommend referring to the detailed guide below to get started with Action Builder:
https://forum.pabbly.com/threads/pabbly-action-builder-guide-for-creating-custom-action-step-apis.35633/post-167279
Hi @doonlawmentor,
The Webinar.gg app is now live. You can try out the actions. Please let us know how it goes.
