How to create Al Multi Agents workflow?
ravimittal7
Ok.. Can you please share videos links on how to use AI Assistant (Pabbly) & what should I write if I want to use o1 & o3 models?
Hello @ravimittal7,
Please refer to the attached video tutorial to learn more about using the AI Assistant (Pabbly).
You can select the required AI model by choosing it from the OpenAI Model dropdown. If the desired model is not listed, you can simply turn on the Map option and manually enter the model name to use it.
Let us know if you need any further assistance.
ravimittal7
I am using AI assistant (Pabbly) now but can't use GPT-o1 model. There was an error that temperature setting is not valid in this Model. Please suggest. I just want to use o1 model to write a title or content topic idea.
Hello @ravimittal7,
The model we use does support working with vector stores; however, the specific version you are trying to use (GPT-01) doesn't seem to support this functionality, which may be causing the issue.
This limitation could be why the temperature setting is not being accepted as well.
For generating a title or content topic idea, we recommend switching to a supported model version to ensure smoother operation.
ravimittal7
Hi, where can we see the AI Agent created? How can we get AI Agent Id and how can we make changes to the prompt of these AI Agents?
You know there is HUGE LIMITATION to your AI Agents due to which actual automated workflows aren't achieved.
When can I expect AI Agent like in n8n be available in your system? n8n is an open source and it can be hosted easily on VPS.
