How to Create an Automation in Pabbly Connect to Grant Thinkific Course Access Based on an Active Campaign Tag
I have created an automation and need help configuring it in Pabbly Connect. The objective is to grant course access in Thinkific to users who have a specific tag in ActiveCampaign. The tag has already been created in ActiveCampaign.
I would like guidance on how to set this up in Pabbly Connect so that the automation only triggers for users with the selected tag. Specifically, how can I ensure that this automation runs exclusively for users with a particular tag in ActiveCampaign?
Your detailed instructions and insights would be greatly appreciated. Thank you!
Hello @imtiaz ahmad,
You can set up your workflow with the following configuration:
  • Trigger: ActiveCampaign - Tag Added or Removed from a Contact
  • Action: Thinkific - Enroll User
Please refer to the attached image for more details.
Kindly try setting up the workflow, and if you encounter any further issues, feel free to let us know.
You can add a filter after the trigger step to ensure the workflow only proceeds when a specific tag is present.
Please capture a trigger response by adding the required tag to the contact and let us know so we can suggest a field based on which the filter could be set.
