how to get the data from webhook in python dataframe ?
ranganna
Hi Team,
I have created the webhook I want to read the webhook data in data frame in python.
Kindly help on this as soon as possible.
Regards,
Ranga Naik
Active member
Hello @ranganna
Please confirm if you want the data received in the trigger step of the workflow named CASH ST Buy Hourly to be sent to your Python dataframe and then get the analyzed response in Pabbly Connect.
ArshilAhmad
Moderator
I'm afraid the use case you're describing doesn't seem to be possible. You can try using Code by Pabbly to run a Python code if that's what you are looking for.
Active member
Hello @ranganna
Unfortunately, the use case you are trying to achieve is not possible with Pabbly Connect.
You can receive responses from Python code (hosted on your local machine) in Pabbly Connect via a webhook, but sending data from Pabbly Connect to your Python code is not feasible.
can't we recieve response from webhook in python code..
If you're looking to use SQL Workbench, we do have a native integration available here: https://www.pabbly.com/connect/integrations/mysql/.
I have so many look up SQL tables
You can also explore other integrated apps with Pabbly Connect by following this link: https://www.pabbly.com/connect/integrations/mysql/.
