How to remove duplicates of values after 'extract by pattern'?
I use regex to extract some tracking IDs from webhook input.
when using advanced response option, I am getting the below Result
["GTM-NDL2SG5","GTM-NDL2SG5","GTM-NMW4Z2Z","GTM-PLMC79W","GTM-P3DB5M4","UA-81353324-1","AW-877300671"]
as you can see, there is a duplicate value in the above line.
How can I remove this duplicate?
I tried to use spreadsheet formula, but it doesn't work.
any workarounds for this?
Hey @botbuilders_tech
You can try using the "Text Formatters" Extract Pattern action event to extract the unique values from your string.
For this, you can refer to some of the online Regular Expression tools available.
I hope this might help you out.
