How to send multi-dimensional array with "API by Pabbly"
auguk
I am working on this automation:
https://connect.pabbly.com/workflow/mapping/IjM0MDQ4OSI_3D
I need to send a multidimensional array to Vendus Api, and I am using "API by Pabbly" integration.
Here is an example of what PHP Array Vendus API is expecting:
https://www.vendus.pt/ws/v1.1/documents.doc
> see example for the Create (POST) call explanation.
My question to you is:
How can I pass the multi-dimensional array values?
E.g. 2-dimensions for "client"
Also 3-dimensions array for "payments" and "items"?
How shall I write these values in the "Set Parameters" fields?
Thank you very much for your help in advance.
Pabbly
Administrator
Consider using Custom POST Request as shown below for your requirment. Let us know if that works for you.
