I am doing reel posting for IG and FB
stevenphan
I am doing reel posting for IG and FB. However I don't know what kind of video url is right to do. Can you give suggestion for right video format. Thank you
Hello @stevenphan,
Please refer to the following API docs to learn more about the video specifications: https://developers.facebook.com/docs/video-api/guides/reels-publishing/.
Hello @stevenphan,
You can try uploading the Google Drive link, but please ensure that the content type of the video is in MP4 format.
Please try uploading the video and let us know if it works for you.
stevenphan
Hello @stevenphan,
It seems you're still using the older connection, refer to the attached image. Please try to perform the action with a new connection and let us know if it works fine for you.
Hello @stevenphan,
It appears that the Instagram API does not support uploading files directly from Google Drive via API requests. As an alternative, we recommend using Imgur. You can upload the video to Imgur using the Upload Image action and then use the generated URL to create the reel.
Hello @stevenphan,
It seems the video doesn't fulfill the video specifications(height is below the minimum required height), refer to the attached screenshots. This is the reason behind the unsuccessful upload.
stevenphan
Hello @stevenphan,
In our tutorial, we demonstrated using a Google Drive link for Instagram, but unfortunately, Instagram’s API currently doesn’t support direct uploads using Google Drive URLs.
