I have a problem with a Tally Intergration
Kevin J
I'm actually try to make a work flow between tally, gmail and google sheet.
I have already do it before but this is the first time i meet this problem.When I connect my tally with pabbly with a webhook. (check pic 1)
The response does not appear like on my other workflow their are not on res2 but res1 then it's impossible for me to make a workflow. (check pic 2)
On my other workflow when i connect my tally with the webhook I send data to pabbly and then my question appear on the left and on the right their is the answer I choosed.
Please can you help me I don't find any solution anywhere.
Thank you
Pabbly13
Hey @Kevin J !
Kindly share the workflow URL in which you have tried the setup?
Also, the workflow URL to which you have already done the setup and working correctly as per your requirement.
So we can compare both of them and guide you accordingly.
Kevin J
i find have find where the problem from.
On my Tally I have a question where people can put files when I keep this type of question nothing work all of my automatization failed when I delete it everything work. --'
I think I can do anything with this question.
If you have an idea because this question was important on my form if I have to delete it it will be complicated for me.
Pabbly13
Hey @Kevin J !
Kindly provide us with the workflow URL in order to assist you further.
We cannot provide you with an insight till we have a look on the two workflows and investigate further.
Hope, to hear from you soon.
