Karin on Forum
Dear all,
My exact question is asked in question with the title: Resize or crop image for Instagram
Unfortunately, that answer - cropping - has not helped me.
The image to be posted. Can be an actual file or a public URL. If it is a public URL, it must start with https:// or http://. Supported formats are: jpg, gif, png, ico, bmp.
Maximun image size 8MB and aspect ratio falls within a 4:5 to 1.91:1 range.
I run the Workflow 26 times (according to my Dashboard); I tried all these things:
Whatever I do, I keep on getting the same kind of error notification as is mentioned in this question: Resize or crop image for Instagram
Everything in this video
, I do the same (connecting IG Business, etc), and it runs the same as in the video - until the end: No post for me, but as a response: I get the error notifications.
I use the Workflow link as given in the description of the video, and I insert everything new: like Webhook URL, refresh, etc -
Please help!
Is there a hidden something somewhere? It almost can't be the image itself anymore..
Thank you, Karin
- I have resized my image. While Instagram (via Canva) should be: 1080 x 1080 I resized to 864 x 1080 and then even: 800 x 1000 (because of the 4:5 ratio)
- Just in case, I reduced the size from 1.4 MB (by far not: 8MB) to only: 118.03 kB
- I tried URL via Google Drive
- I tried URL via Dropbox
- I contacted Dropbox to see if this was not public enough; they said that with my type of account: this URL should work. (And I can see the image even in an incognito window when using the URL; so it should indeed be public/ shareable.)
- The URL I use starts with: https://
- I tried photos in the format: jpg and png
Google Sheets to Instagram | Automatically Post from Google Sheets to Instagram
Please help!
Thank you, Karin
