Is it possible using pabbly?
Status: Closed · Asked by rohitkrmaurya on · 0 views
rohitkrmaurya — Question ·
I need a feature in which I can copy the connected setup of a google form and its formatted google spreadsheet where form submitted data is stored and there is one more sheet with that spreadsheet which further refines that data and bring it into certain formatting to make better use of submitted data.
So please tell me about its possibility using pabbly ?
Hi @rohitkrmaurya,
Could you please make a short screen recording and elaborate a bit more on your exact use case? This will allow us to assess its possibility.
rohitkrmaurya — Reply ·
Hi @rohitkrmaurya,
I have created a Google Forms template with its response sheet in which a new sheet is also created that fetch data from response sheet using sheets formulas and generates charts and progress bars for better decision making on data received from response sheet. I want to create a system where users can fill out a form to receive a customized link to this template. So, I want your services to automate this process.
Hello @rohitkrmaurya
We are still quite not clear on your concern. Please elaborate a bit more on:
1. Flow of data(eg: form fill> send email).
2. The application you are planning to use to send the customized link.
3. Please clarify what you refer to by the customized link.
I think the thing I was trying to do is not possible in automation mode. Manual steps are required each time. (Sending Google form with its connected response sheets on a Gmail so that they can too start using it instantly and get form responses in their owned google sheet)
So I am leaving this problem.
Thank you for your kind response
If you require automating your workflows shortly, please let us know.
