ISSUE WITH ZOOM REGISTRATION
Pabbly
Administrator
For the Zoom action step, the authorization token seems to be expire as result of which error was appearing -
You will be needing to reauthorize the Zoom application once as shown here -
Pabbly
Administrator
Zoom provides a token key (kind of secret key) in order to make the integration possible. This token key has a certain time before they are being expired from Zoom end itself, and thus you see the error as shown below -
So whenever you see these sort of errors, you will be simply needing to reauthorize the integration and it will start working.
Hope the above information helps.
