Issues with integrating Go High Level with Aweber
JayP
Trying to integrate GHL with Aweber. Attempted a test submission but nothing has happened and the Trigger action on Pabbly still says "waiting for webhook response". What do I need to do, what am I missing?
Pabbly13
Hey @JayP !
Kindly make sure that you have followed every points of the helptext and do make sure that the Webhook is "Activate" in your account as well-
Once checked all the points for your setup, kindly do a test submission by adding a new lead to a particular Campaign.
The response will get captured and you can use this new response in your Aweber step.
Do check and let us know if this works for you now.
JayP
This was set up exactly like this but has still not worked for some reason.
There must be something I'm missing
Adarshs
Hey @JayP
After Save & Send Test Request, trigger will wait for the event response. To capture the response please try to Add customer or lead to a campaign in your highlevel account.
Follow these steps and let us know is it working for you?
