iTERATOR NOT CONVERTING DATA WHICH IS REQUIRED IN JSON FORMAT
studycafe
Dear Team, I need to send bulk messages and for that i am using this video
Problem is that iterator is not converting the data which is required i Json format. REfer attached screen shot.
Kindly suggest what to do?
Fagun Shah
No need to use JSON extractor anymore, you can use/map values from Iterator results directly now.
Watch video after JSON step, your iterator output should work similarly as JSON Extractor action step output from video.
