MuxEmail Integration Issues
Pabbly
Administrator
Hello Pabbly team ,
I'm the founder of MuxEmail reaching out to you regarding our integration with Pabbly.
We found some issues with the integration and would like you to update it. There is also an update in our API key generation function. We've made this short document so you can check and update easily - https://docs.google.com/document/d/1Dt2PbnvLGOFVNGV5LgSp4baT7PbwpjwS3P5qQSjzf-Y/edit?usp=sharing
Thanks for the document. We are reviewing the doc and will keep you posted with the updates.
