    🔥 Pabbly Subscription Billing One Time Plan for $149 (🏆Lifetime Access) - View offer
my pabbly connect flow is not working
PabblyMember4
Hi @babu,
I have checked the history for this task in the workflow and found that emails are not sending because of the error Message "Recipient email missing".
Could you please check in the form if you have the Guest recipient email id column present or not? If not then kindly create it in the form and map it in the workflow so that your workflow can run seamlessly.
