Need Confirmation on Facebook Automation Workflow in Pabbly Connect
Status: Open · Asked by Arun Gayswal on · 0 views
Arun Gayswal — Question ·
Hello Pabbly Team,
I want to set up an automated Facebook posting workflow using Pabbly Connect, but I need confirmation on whether this is possible. Here’s what I want to achieve:
? Workflow Overview
✅ Step 1: Fetch Past 30 Days of Facebook Posts
  • I need to retrieve all images posted on my Facebook Page in the last 30 days along with their number of likes.
✅ Step 2: Select Top 24 Images Based on Likes
  • I want to sort these images based on the highest number of likes and pick the top 24 most-liked images.
✅ Step 3: Ensure No Image is Repeated in 24 Hours
  • To avoid repetition, I need to compare the selected 24 images with a Google Sheet that tracks previously posted images.
  • If an image was already posted in the last 24 hours, it should be skipped.
✅ Step 4: Schedule 24 Facebook Posts for the Next Day
  • The 24 selected images should be scheduled for posting once per hour (one image every hour).
  • I need to know the best way to schedule 24 posts in Pabbly.
✅ Step 5: Auto-Post to Facebook
  • The selected images should be automatically posted on my Facebook Page with a caption.
  • Need confirmation: Can Pabbly’s Facebook API handle 24 posts per day without limitations?
✅ Step 6: Update Google Sheets
  • After posting, the images should be logged in a Google Sheet to track which images have already been used.
? My Questions for You
1️⃣ Can Pabbly fetch past 30 days of Facebook posts along with the number of likes?
2️⃣ Can Pabbly automatically sort the images based on the highest number of likes?
3️⃣ What is the best way to filter out images that were posted in the last 24 hours?
4️⃣ How can I schedule 24 posts per day at hourly intervals?
5️⃣ Does the Facebook API allow 24 posts per day through Pabbly, or are there any limits?
Please confirm if this workflow is possible with Pabbly Connect. If any part of it requires an alternative solution, I’d appreciate your recommendations.
Hi @sonuku,
You can use the 'Get Page Insights' action step to retrieve details from the past month for the specified page.
Unfortunately, this entire use case is currently not possible with Pabbly Connect, nor do we have a workaround for it.
Arun Gayswal — Reply ·
can we use the deepseek AI instead of chat gpt.?
Hello @sonuku,
Could you please provide more details on where you were using ChatGPT This will help us better assess whether DeepSeek can serve as a suitable replacement. Currently, DeepSeek offers only one action: Create Chat Completions.
Let us know your specific use case so we can guide you accordingly.
For reply Facebook comment and generate the post caption on automation .
