Need Help in setup
rkvkuleep
I am using Zapier right now and it's very easy to use and setup but Pabbly is very difficult to setup so if someone can do my setup then i can use Pabbly! I was trying to setup but all my tasks consumed while setup only don't know how?
rkvkuleep
1- wpfrom->sendinblue create contact
If Someone fill wpform to our site http://pretutorials.com/ then create a contact in a particular list
2- sendinblue create contact-> google sheet-> google contact
If a contact is created then details should save in google sheet and automatically create a google contact
Hey @rkvkuleep
Please check out the following screenshot, follow the help text mentioned in the trigger/action event.
1. Capture the webhook response after setting up the webhook URL as instructed in the trigger.
2. Add an action step of SendinBlue pick the "Create a Contact" event then connect your account and then map the values from the WP forms webhook response to add contacts in your SendinBlue account.
For your above use case, you can check out our tutorial video for a better understanding.
Kindly try this at your end and let us know if you get stuck at any step.
