need help setting my conversion API for meta ads
Status: Open · Asked by Alaa Bebar on · 0 views
alaa bebar — Reply ·
im updating the request for help for my understanding I can use the online conversation API
here's the workflow I have set, I just need help with the automation I have set so that automation sends the lead information once because the way I have set the automation it scans the column "closed" and I'm wondering if the automation will keep sending data to conversation API more than once, and how can I fix that.
also, the function for the lead option includes a necessary currency and value that need to be removed
here's the updated workflow : https://connect.pabbly.com/workflow/mapping/IjU3NjUwNTZiMDYzZTA0MzI1MjY0NTUzMTUxMzMi_pc
need help setting my conversion API for meta ads.
here's the workflow I have created :https://connect.pabbly.com/workflow/mapping/IjU3NjUwNTZiMDYzZTA0MzI1MjY0NTUzMTUxMzMi_pc
need help with this part :
Please follow the steps given in the video shared below:
youtube.com/watch?v=J7mSP125N6o:502
Yes, your workflow will trigger every day at 9 PM to check for 'נסגר' in your spreadsheet. If it is found, the next steps of your workflow will be triggered. Once it finds 'נסגר', it will send the offline events. This process cannot be stopped unless 'נסגר' is changed in your spreadsheet.
Both of those fields are required from Meta's end. We cannot change them to be not required; the action event will not work.
You may want to check out the video shared below, as it seems that you haven't entered the details in the 'Send Offline Event' action step according to the help text.
Please check out this video:
youtube.com/watch?v=rCw_aGVFtz4:368
Hello @ArshilAhmad , long time since heard from you on the forums, how can I resolve that I sent the event once not various times with the value lookup by Google sheet this status be tracking for performance and statistical purposes, or the event automatically will link once with Facebook ads
the purpose of this automation is sending a lead event not a purchase event, I have watched the first video with the amazing staff member of Pabbly but he's using a regular API and a purchase event.
I'll watch the second video with and I'll keep you updated
for the start point I want to optimize on a closed lead, and after that when the collection department deals with this deal the purchase values will updated to this lead for a start point I just want to send relevant data regarding the lead, not a purchase event that includes values and current because it yet doesn't finish working with the lead a service provider.
my question is even if I've entered a value of 1 in the value mapping part, can I add an in the future an update regarding the purchase amount linking to this lead?
in other words, I want to send the event once, and can able to build another automation in the future for the fee collected fro, this specific lead.
Please allow us some time, we are looking into it.
Could you please record a short video elaborating a bit more on your exact concern?
Please allow me some time to discuss this with my team. We will get back to you with an update soon.
thank you @ArshilAhmad
The only suggestion I can offer you regarding this workflow is to add a Data Forwarder and place all the remaining steps in a different workflow. You cannot include both Delay and Iterator in the same workflow, as it will cause issues.
This is a general guidance that you can apply for other workflows as well. As for this particular use case, it doesn't appear to be possible for now.
thank you man
okay thank you @ArshilAhmad
I had a discussion with the technical team, and they have informed me that it's not possible to skip the Currency or its value; it's required from Facebook's end. This Currency and Value will affect your optimization and data.
We don't have information on whether or not the same lead would be updated when you use 'Send Offline Purchase Event' later. You can try entering the same Match Key Phone and Match Key Email in 'Send Offline Purchase Event' for testing and see if that updates the lead details or create a new purchase event entirely.
can the technical team make the value and currency part isn't required to save and send the request?
It is a required field on Facebook's end and cannot be made non-required in the action step; we have already discussed its possibility with the team.
even for sending a lead event, not a purchase event? @ArshilAhmad
Yes, even for 'Send Offline Event'.
I found an alternative solution for the other automation we discussed can you have a look at why I'm getting an error message when I try to upload a file within the mapping I included?
workflow:https://connect.pabbly.com/workflow/mapping/IjU3NjUwNTZiMDYzZjA0M2Q1MjY4NTUzNDUxM2Ii_pc
can you have a look and assist me with it please?
The Email Parser attachment stored on our servers expires in 48 hours. Try using a different attachment.
is the search folder part will search only for the revenue folder name in Dec 2023 per say if I have a Nov 23 folder for the previous month that contains folder named revenue also?
It will search for all the folders named 'Revenue' in your Google Drive.
Could you please help me here to adjust the workflow to achieve my use case, i have tried to run a new response from both workflows.
For this workflow, i have a couple of things that I need your help with @ArshilAhmad
Could you please record a short video and elaborate a bit more on the exact issue you are encountering?
Please check your another thread for the same query.
@ArshilAhmad Hello friend, Here is a video recording of what I'm trying to achieve.
https://drive.google.com/file/d/1Cw75xgTmWBV_J1XiQr5-aRXeJkbwWaup/view?usp=sharing
can you me adjust the workflow please
I'm afraid we won't be able to set up the workflow for you or guide you regarding the router conditions. We suggest that you hire a Pabbly Connect expert who could set up your workflow and route conditions on your behalf and also manage your workflow.
https://forum.pabbly.com/threads/pabbly-connect-experts-and-consultants.22/
As for the issue related to 'Upload a File' action event. Kindly share the URL of the attachment you are trying to upload.
We will look into it, please allow us some time.
As mentioned previously, I don't think the use case you are trying to achieve is possible, so I won't be able to assist you in setting up the Router conditions.
https://connect.pabbly.com/workflow/mapping/IjU3NjUwNTZhMDYzNDA0MzM1MjZiNTUzMjUxMzUi_pc
Regarding the issue related to file upload, the file does appear to be getting uploaded to the same folder when I tried to upload it manually.
Task History ID: IjU3NmMwNTZlMDYzMTA0MzQ1MjZlNTUzMzUxMzA1MTYwNTQzOCI_3D_pc
However, I'll need to discuss with the team why you are encountering the ScriptError in automation. I'll get back to you with an update soon.
I might need your help with sending data from Google sheet to Google Analytics, which command option does I have looked all over YouTube for videos regarding Google Analytics data sending to measure KPI with no success finding any @ArshilAhmad
https://connect.pabbly.com/workflow/mapping/IjU3NjUwNTZhMDYzNzA0MzI1MjZkNTUzZDUxMzAi_pc
Google Analytics has no such action event that could help you transfer the lead data from Google Sheets to Google Analytics.
could I create an alternative solution for my use case to send the data from another source by sending it from my Google Sheets?
Sending source is not the problem. Google Analytics itself does not have an action event through which you could transfer lead data.
Our team suggests that you try again and see if you encounter the ScriptError now or not. Please ensure that you use a new attachment.
