Need Pabbly video connecting Calendly with Zoho CRM create Meeting/Task record and connect to existing Contact
rcsvoboda
Need Pabbly How To video connecting Calendly with Zoho CRM create Meeting/Task record and connect to existing Contact via Contact email address
rcsvoboda
Using Pabbly integrate Calendly with Zoho CRM Meeting or Task Module
Calendly Invitee Created
Creates Calendly data in Zoho CRM - Meeting/Task Module
ArshilAhmad
Moderator
Although we don't have a dedicated video for it, the use case you are describing is possible. Kindly refer to the attached screenshot for a clear understanding of how the workflow will be configured.
I am attaching these videos for your reference. While the steps may vary slightly from your specific use case, the concept remains the same.
