Need Recommendation
Status: Closed · Asked by Zest83 - on · 0 views
Pabbly Recommended Chat-API in one of their videos to send messages using WhatsApp
We would like to start using WhatsApp Business API
But this will include other integrations - correct... Beside the API URL & TOKEN
Which service do you recommend we can use to get started with WhatsApp Business - while using Pabbly for all our Integrations!
Chat-Api was a brilliant suggestion!
Now, need a suggestion for WhatsApp Business API
Pabbly Recommended Chat-API in one of their videos to send messages using WhatsAppWe would like to start using WhatsApp Business API
But this will include other integrations - correct... Beside the API URL & TOKENWhich service do you recommend we can use to get started with WhatsApp Business - while using Pabbly for all our Integrations!
You can consider using 360 Dialog WhatsApp Business API for that. Check this tutorial for full information -
IN the video, it says, you have launched a service at $5 a month. How do I avail the same and learn more about the same?
Follow this link - https://forum.pabbly.com/threads/urgent-unable-to-change-my-connection-in-chat-api-trigger.4356/post-20966
