Not able to store elementor webhook response to bigin fields
Status: Closed · Asked by Info on · 0 views
unsaidtalks — Question ·
We are trying to capture the webhook response for an elementor form, and then storing that data in the bigin.
But in our workflow, the webhook response fields are getting captured correctly, but for some of the fields the data is not getting stored in the bigin from the create and update actions.
Can you please help resolve this?
Gunjan — Reply ·
Could you please share more information on the fields for which the data is not being transferred to Bigin? A screenshot of the workflow configuration and Bigin after creation would be helpful.
unsaidtalks — Reply ·
Following is the screenshot of the workflow action:
Following fields are not getting saved withh data on bigin:
1. Graduation Year
2. College Name, Branch And Graduation Year
3. Assigned Tag On Systeme.Io
4. Contact Created On
Note - these fields are custom fields which are created in bigin.
Following is the workflow link - https://connect.pabbly.com/v2/app/workflow/mapping/IjU3NjYwNTZhMDYzNDA0MzQ1MjZmNTUzYzUxMzEi_pc
Please let us know if you require any further details
Gunjan — Reply ·
The action seems to have configured fine, let the Pabbly team check this now that you have added the details, it would help them.
The 'Last Name' you are passing in the 'Update Contact' action step doesn't appear to be correct — it contains brackets and a comma, which is likely causing the error. Please correct this and see if it resolves the issue.
