OPEN Ai Extract PDF Errors! Webcontentlink issues
Status: Closed · Asked by AussiePete on · 0 views
I cannot succeed in obtaining the PDF. I have tried Dropbox, Onedrive, Google Drive URL LInk to the PDF. I have used very possible link configuration. I just get continuous errors. have been tryin got solve this for 48 hours.
Try this action. FYI I'm not from Pabbly Connect team, just a freelancer who helps other Pabbly users.
thanks for the suggestion. A different error has appeared. Which I've encountered often while tryin got execute this action
Have you checked the file if it's public or not and can you please upload whole screenshot if possible
Your schema is incorrect
it should be in this format
"name": "expense_data",
"schema": {
"type": "object",
"properties": {
"editions": {
"type": "array",
"items": {
"type": "object",
"properties": {
"Edition": { "type": "string" },
"Quantity": { "type": "number" },
"TotalAmount": { "type": "number" }
"required": ["Edition", "Quantity", "TotalAmount"]
"notes": {
"type": "string"
"required": ["editions"],
"additionalProperties": false
"strict": true
and check your file extension use above mentioned extension instead of ".bin"
"type": "object",
"properties": {
"editions": {
"type": "array",
"items": {
"type": "object",
"properties": {
"name": { "type": "string" },
"price": { "type": "number" }
"required": ["name", "price"],
Try this. If still not works you can dm me I'll help you out with this
