Pabbly & LeadConnector
learo
Hi folks, for some reason I can not see Notes or Message body fields for "Create Opportunity" task in Pabbly for LeadConnector. Is there a setting that I need to enable? How do I access those fields?
A
Arshita
Hey @learo
As we can see from LeadConnector/High Levels' API documentation, we couldn't find any option to do the same and they haven't mentioned any support for Custom Fields in creating the opportunity.
So, we are currently working on it and will notify you with an update soon.
