Pabbly <> Pipedrive Integration Not Working with Stages of Deal
Xartup
Hi there
I am trying to integrate a workflow where pabbly connect should trigger and send a whatsapp text when 'A deal is added to a specific stage in the pipeline'. But, looking at the options, it seems like it works in the same way for all the deals. Is there a way in which we can make pabbly trigger specifically on stage-wise movement of a deal in a pipeline. We want to send different whatsapp texts in each stages.
Supreme
Hey @Xartup
Regarding your concern to send messages on the basis of different stages, you can use the "Router" action step where you can set individual routes for your respective deal stages.
Further, you can also refer to our tutorial video for a better understanding. Kindly try this at your end and let us know if you get stuck at any step.
