Pabbly Text Formatter not cleaning up \n
Your Workflow URL
https://connect.pabbly.com/workflow/mapping/IjU3NjcwNTZkMDYzMDA0MzU1MjY0NTUzYzUxMzAi_pc
Consent to Access & Modify
I authorize Pabbly Support to log in to my account and make changes to the specified workflow for troubleshooting.
I have used the formatter to replace \n but still in my final API output it is showing error caused due to \n.
Please check it.
Tell me the reason why I am not getting final output.
Hello @Yash Bhojwani,
We thoroughly checked your workflow and formatter. The 3rd response does not contain any \n or \r characters, so the Text Formatter is working correctly.
The error seems to be coming from the API request/code itself, as it fails with any combination we tested. Please recheck the request format or try running the same request in another API executor (for example, Postman) to confirm.
Also, kindly share the API Docs and the specific endpoint you're trying to perform so we can assist you effectively.
