Pabbly workflow automation using Spayee(Graphy)
tejasvi
I have the business plan of Spayee(Graphy). I want to automate the task of pulling the users who have subscribed using the contact us form to be converted to new learners on the platform. I took reference of this guide here and was able to create a workflow. The workflow had two steps-
1) Trigger on the new subscriber event in Graphy to generate a response.
2) Use this response to convert them to learners using the Create a Learner trigger.
I was able to do the process by providing api key in integrations in Pablly Connect for Spayee for the new subscriber event. For the Create a learner event I added a webhook url for the same.
I was successfully able to run the workflow after doing the mapping. But I had to refresh the response generated for the new subscriber event to generate a new entry each time. I want to automate this entire workflow.
Is there a way I can accomplish this? Or am I missing something here?
Hey @tejasvi
Could you please share a short video on how you are trying to trigger the webhook of Spayee for a new subscriber?
Though your workflow seems fine to us, kindly try again or try recapturing the webhook response again.
tejasvi
Hi @Supreme Thanks for replying. What I tried to accomplish, I have tried to capture through a video. If you see I have to click on the Test button again and again to get a new response. Also to be passed to the next stage of pipeline I have to manually select these mapping values.
I want this workflow to be automatically triggered so that when a person subscribes using the contact form the workflow autopopulates the values and pass these to create a learner step of the pipeline.
Let me know if anything else is needed from my side or you need more clarifications.
Hey @tejasvi
We looked into your workflow and its webhook response. So, we have tried re-creating the same at our end and the webhook is working accordingly.
Though we have recorded a sample video, for your better understanding. Please check that out and try again at your end.
Regards
