please help - Request is missing required authentication credential
wizi
I am trying to setup an Random auto response to google review following this video
But I am getting this error at the very last step.
What did I do wrong? I thought I already authorize the worksheet in the previous steps. How can I fix this?
Thank you
The workflow name is Nails 8002 (Mesa, AZ) - Random Reply Reviews
It appears that you might have made some changes in your GMB account and because of that the issue is coming in the GMB action step.
So, please add a new connection and try again.
wizi
I added a new connection with a new gmail but its still getting the Credential Error. can you take a look at my work flow? thank you
wizi
The link you provided has error. Do you have a video from pabbly showing how to do it?
But. I dont understand why do I need to add Google My Business API? And how does it related to accessing google sheet?
Hey @minhlily
Please check the same with the Google My Business support team or the Google Workspace manager. Perhaps this might help you out.
wizi
Hey @minhlily
After reconnecting the GMB action step, your review is now getting posted. Please check your workflow and try the complete execution accordingly.
So, kindly reconnect all the GMB action steps inside the router action step.
Hey @minhlily
Can you please check and confirm for us that the workflow is processing the review accordingly?
Kindly do let me know if you require any other help.
