Please help- whats the right folder path for dropbox
Status: Closed · Asked by maresa22 on · 0 views
been trying to connect to my drop box folder where i want to use the images and upload them to pinterest but its been giving me error due to path fater connect to the dropox. whats the right folder path for dropbox? ive tried /pathname, pathname, path name. none works .
Hello @maresa22,
[IMG width="596px" height="179.207px"]https://lh7-rt.googleusercontent.com/docsz/AD_4nXdIIyAufG9PAvCMwc7x1WY0E6w-WgObXRlDSnKHf1PewZr-urLvTqzndJMf1jslcx3-PFVZpkHCLDWTzYKpKrFN9L7hz7MoZPP2vTzQTXxLTo_qGsZpa8gqaPgY_WmF7dHtThGu?key=PL4GUVQWZ8u13PditD4i_cYb[/IMG]
its
pinsa Workflow
Hello @maresa22,Could you please provide us with the Workflow URL where you are facing this issue? This will help us investigate the problem more effectively and assist you accordingly.
its
pinsa Workflow
Hello @Maresa,
Could you please either share the workflow URL, as indicated in the attached image, or provide the email address associated with your Pabbly Connect account
This will help us investigate the issue more effectively.
Hello @Maresa,Could you please either share the workflow URL, as indicated in the attached image, or provide the email address associated with your Pabbly Connect account?
here is my email for it: [email hidden]
Could you please share a screenshot showing the path to the folder in your Dropbox account?
Also, check out the video below, which shows how you can set up Dropbox as your trigger step.
