PLESE HELP with ClickFunnels / Zenler Course
Status: Closed · Asked by larrys on · 0 views
larrys — Question ·
Hello! I just signed up for Pabbly Connect and I need to connect a Purchase in ClickFunnels so it Enrolls the person into a course in my Zenler account.
I just watched a video about doing this with ThriveCart, excellent! So, I know it works. And I see Pabbly does work with ClickFunnels. But, Here is are my questions...
First - DO I have to first make an action to make the person a "USER" with a "STUDENT" role in Zenler, as in the ThriveCart video? Is this so I can give them a password?
OR: Can I simply Enroll the person into the course directly when they make the purchase in ClickFunnels.
From the video, it appears that it has to be a two step process. First make the person a USER, Give them a PASSWORD, and then create a second step to ENROLL into the course.
Then the big question is -
How do I send them the login info / temporary password so they can immediately access the course when they make the payment in ClickFunnels?
The teacher in the video said there is a way to email the person right from inside Pabbly, but he did not show how to do it. How do I do this?
Please advise,
Thanks!!
Hey @larrys
To enroll a user in a particular course you might need to add a user in your Zenler then only you can add it later.
For this, you can check out the following screenshot and also shared a workflow with you so that you can copy the steps from there, for better understanding -
Kindly try this at your end and let us know if that works for you.
Workflow - https://connect.pabbly.com/workflow/share/CEBQYlYRAypUHwdDDk1UNwAXAwBVHwdRVDMHFQ##
https://forum.pabbly.com/threads/how-can-i-configure-the-zenler-course-enrollment-efficiently-in-pabbly-connect.118/
