Plutio create people and company issue
Neo Wang
I want to create Company with people, but there is no option now.
I try to using hooks data to Plutio both Company and people then create proposal, I try to add Company first, but it request to fill people, but I still no people with this company, if I change add people first, it will request me to fill Company, but I still have no Company to select, I try to mapping, but it will show error.
How to both import Company and people?
Hey @Neo Wang
For your concern you need to 2 action step where at first you can create the person with the help of "Create Person without Custom Fields" and "Create Company with Custom fields", please check out the following screenshot for better understanding.
Neo Wang
Hi, Thank you very much, but it's only work for this people.
I'm using Elementor to create the data, If I submit another data, it will still using that people's info.
Can I let it automatic fill my new submit every time?
Hey @Neo Wang
It seems like you didn't map the person field with its ID in your workflow and because of that, you are having this response.
Though we have done the correct mapping for you, kindly try again.
