Possible to post blocks to Slack?
Status: Closed · Asked by celebrityagent on · 0 views
celebrityagent — Question ·
Within Slack, you can use their Block Kit Builder to create custom payloads for Slack notifications.
Is it possible to post these Payloads to Slack via Pabbly?
JJJJJJJJJJJ — Reply ·
There is a “Send Channel Message (using Block)” action for Slack.
But I don’t get it to work even with a payload copy/pasted from a template provided by Slack themselves…
Could you please share the Workflow URL where you attempted to execute the endpoint? Additionally, could you provide the API documentation and the cURL command for the endpoint you are trying to execute?
NBMath — Reply ·
Hi, I have a similar issue where using the "Send Channel Message (Using Block)" there is no way to change the Message Blocks 0 Type is always 'context', meaning whatever posted is small. Entering Blocks code to set the type has no effect. Is it possible to change this?
Sorry if this doesn't fit here
Please create a new thread and elaborate on your exact concern by recording a short video. Also, share the workflow URL where you have this concern in the same thread.
