Problem Connecting Paably form output data into chatgpt
Status: Closed · Asked by mbest on · 0 views
I am trying to connect the data from my pabbly forms to chat gpt to produce a document based on the data captured from the form. However It seems that I am stuck because when I run the test the AI column says the following: " I'm sorry, I cannot input the answers from the pre-consultation form for a specific storefront as I do not have access to such data. I am an AI language model and I don't have the ability to collect information from external sources." I though that mapping was suppose to connect the current forms output data from the pabbly form? What am I missing here please help?
Hey @mbest
When you see the message, "I'm sorry, I cannot input the answers from the pre-consultation form for a specific storefront as I do not have access to such data," it means that the AI model cannot directly gather data from the API call because it doesn't have the ability to access external sources.
We recommend you check the prompt you are passing or contact the API support team on the behavior of the application.
But the application that I am trying to get the data from directly is from a pabbly form. I am going to attach a short video to try and explain better what my issue is
Please watch this video to understand how you can map data in ChatGPT action step from above.
OK I am having a new problem where I am trying to update the form because I have made some changes to it. When I go to click on the "webhook response button to ensure that response received is the new updated version of the form the button just keeps on buffering. I tried hitting f5 to refresh the screen and I even closed the pabbly connect application and came back in and it still just keeps buffering as shown in the caption Please help.
Please follow the steps given in the video shared below to setup Pabbly Form Builder as your trigger step and capture response:
youtube.com/watch?v=6Bwq_C16vho
Make sure to make a test submission the way its shown in the video.
