problem in connecting with facebook lead to google sheet
Status: Closed · Asked by NAGAA2003 on · 0 views
hi . this is NAGAA.
please help me to connect facebook lead form to google sheet. i have tried but could not connect. pls help
Hey @NAGAA2003
You can refer to the following video tutorial on your concern. Kindly try this at your end and let us know if you get stuck at any step.
THANKS FOR YOUR REPLY. WHEN I WANT TO CONNECT WITH FACEBOOK LEAD TO GOOGLE SHEET I HAVE GOT RESPONSE LIKE THIS. AFTER THIS I COULD NOT MAP. PLS HELP ME IN THIS REGARD
Hey @NAGAA2003
Kindly reconnect the Facebook trigger event and capture the New Lead properly, as we can see from your screenshot you haven't captured the lead completely.
Please try again as mentioned in the tutorial video and let us know if that works for you.
Hi, I also tried reconnecting the Facebook trigger. But it still stuck on capturing webhook response. please help, I don't know what to do. Thank you
Hey @NAGAA2003Kindly reconnect the Facebook trigger event and capture the New Lead properly, as we can see from your screenshot you haven't captured the lead completely.
Hey @moshenatividad
Kindly refer to the following thread for your above concern and then try again. Afterward, make a real submission from your Facebook lead ad form.
Hi, it is already solved. Thanks to Neeraj!
