Problem LeadConnector V2 : Create or Update a Contact
Status: Closed · Asked by Revolution Marketing on · 0 views
Lorenzo — Question ·
Hello guys,
I'm running this flow: IjU3NjYwNTZjMDYzMjA0MzA1MjZkNTUzMzUxMzAi_pc
If I run each step for the first time I see that all the responses are ok but at the same time my contact is not updated with the new data into the custom field (in this specific case with the "INPROGRESS" state).
If the webhook is attivated or I run manually a second time the las step of the flow it says: Pass at least one of number, email query parameter
As you can see the mail is there and also the first time there was not this error....
How can I solve these problems?
Many thanks in advance from an iced Portugal.
Regards,
Lorenzo
Hi @Lorenzo,
It seems that you made some changes to your workflow after encountering those errors, which makes it difficult for us to determine the exact cause of those errors. However, it appears that the changes have resolved the issue.
