Problems with running a workflow continuously
Your Task History ID
IjU3NjYwNTZlMDYzNzA0MzA1MjZiNTUzNzUxM2Ii_pc
As a team member, I created a workflow based on the "RSS by Pabbly" trigger (new item in the feed) to publish messages from RSS to Telegram. In test mode, this workflow works fine, but for some reason it does not run on a regular basis according to the specified interval.
Please tell me what needs to be done to fix the above problem?
Unfortunately, choosing: New Item in Feed (Beta) also does not solve the problem. As a filter, I select the recommended option (default) since I have a standard feed that has a pubDate.
Good day!
I would like to know how the solution to my problem regarding RSS by Pabbly is progressing? Please, give me an approximate estimate of how much longer I should wait for the solution to my problem?
Hello @Alexander Lukyanov,
Our team is currently investigating this issue, but we are unable to provide an estimated time for resolution at the moment. However, we will notify you as soon as the issue is resolved.
Additionally, we have set up a workflow in your account to test the functionality, so please avoid deleting or moving it to the trash.
