Retweet: How can I create an automation workflow to Retweet?
ArshilAhmad
Moderator
Hi @Dalia,
The use case you are describing is currently not possible as we don't have an action event that could help you retweet. If you want this particular action event to be added to Pabbly Connect, you can submit your request on our dedicated platform:
https://pabbly.featureos.app/b/Update-Existing-Application
Our integrations team will look into your request and, if possible, add the desired action event to Pabbly Connect.
