SEO Automation Suggestion
gregdev
Good day everyone. I currently work with an Agency, so what they do is basically SEO. Currently I have helped in setting up an automation that created daily blog post using Open AI and then the automation creates a post on all major social media platforms and also platforms like HubSpot CMS, Blogger etc. The main idea is to have domain authority. Can anyone one suggest any other automation idea I could use to help with SEO. Thanks
ArshilAhmad
Hi @gregdev,
Although not specifically related to SEO, you can check out our YouTube channel to understand what kind of automations you can achieve using Pabbly Connect.
mergerdomo
what about the backlinks do u have any idea about the backlinks
Similar threads
Replies
0
Views
7K
PabblyMember3
