strange code error
Stuart
In javascript code I got a very strange error, It has absolutely nothing to do with my code!
I only got the error twice in all my tests?
Himesh
Active member
Hello @Stuart ,
Looks like this error is coming from shopify's end. Please make sure you are not using any VPN. Please refer the below link. Some of the users are facing same issue.
FYI I'm not from Pabbly Connect team, just a freelancer who helps other Pabbly users.
Stuart
That's true but I am not using a VPN nor am I using Shopify! in fact the first time I saw the error it was just a javascript code calculating values, without any webhooks!
Stuart
hi @ArshilAhmad !
its not really the workflow, which is working fine. I just thought someone should be aware of it. the error is in the log and not affecting functionality.
however, I cant really test it many times anymore because the code sends some webhooks out (to pabbly, not to shopify!)
