Telegram problem !
I want help / I don't know what's wrong
When I pressed yes
Workflow has already repeated the request too many times
What mistake am I doing here when I am at the beginning of Workflow?
قد تكون صورة ‏تحتوي على النص '‏‎Trigger: When this happens 1.Telegram Bot: Set Webhook/ Watch Updates Choose App Help Instant Telegram Bot Free ask Trigger Event Set Webhook Watch Updates Connected Simple Response Save Send Do you wish to resend the request again? You have already used the event Set Webhook Watch Updates of Telegram Bot for this workflow. If you resend the request, duplicate data for the same event may arrive. This may affect your workflow by making it execute multiple times for the same event. Action 2. Cho Do you still want to resend the request again? Choose App Yes No‎‏'‏
ArshilAhmad
Moderator
Hi @karimsalah,
  1. If you have clicked on 'Save & Send Test Request' only once, then you can click on "Yes" and continue to set up the next steps of your workflow.
  2. In case you have clicked on 'Save & Send Test Request' more than once, disable this workflow and create a new workflow from scratch (without cloning).
Good @ArshilAhmad
I created a new Workflow and deleted the old one
The problem is that Telegram brings old data every two minutes or more from old messages on the channel
I don't know what the secret behind this problem is
Why does he repeat the process over and over again?
And not based on updates and new messages!
