Telegram
Hi, my English isn't very good, so I'll use a translator. Unfortunately I have encountered a problem. Attached you will find the screenshot. What should I do?
Thank you
C
A
Arshita
Hello @Seed Vicious
Upon investigation, I have discovered that you are using the "div" version in the chat ID field which was causing an issue in your workflow.
We have corrected this, and it should be working perfectly fine now. I recommend that you check the workflow from your end and let me know if you are still experiencing the same issue.
Additionally, I would like to inform you that we have upgraded the Telegram bot application. Therefore, I suggest that you use the upgraded version to avoid any further issues.
