Temporary variables and sequential routing
bandelero
Dear Pabbly Team,
I finally had a chance to look at the custom variables feature you've recently added. I realized that your implementation of custom variables is "global" as opposed to temporary - e.g. live within one execution of a workflow.
I think this misses a huge use case, specifically when temporary variables are used with sequential workflow routing.
I'm sure you know that in Make you can set your variables to be "live" for just one workflow run (cycle). And when you use them with routers (which are sequential in Make), you can use these temporary variables to pass information between branches of a router.
For example, say I have an automation that uses an LLM to summarise a piece of text. I in Make I could build a router with three branches:
(1) If the text is shorter than 10k words, send it to GPT-3.5-16k for processing and deposit the GPT output into a temporary variable (e.g. "summary_text")
(2) If the text is longer than 10k words, send it to Claude 2 vis OpenRouter for processing, and deposit the output into "summary_text"
(3) Unconditional router (runs after (1) or (2) have run) gets the "summary_text" variable and uses its value to write an email
Being able to use temporary variables, sequential router processing and unconditional branching makes it a lot easier and more intuitive to develop complex automations.
Would you consider adding these features?
Evgeny
bandelero
Added!
There already is a request to enable sequential processing of router branches (and to give us a way to reorder the execution sequence). I added the request for temporary (workflow) variables.
